PL mounts on Scarlet FF35 and Epic FF35
Jarred Land
Fire Chief
Staff member
Just wanted to clear up a little confusion, caused by use leaving the option off of the Brochure. ( sorry )
The RED Interchangeable PL Mount will be switchable between both the Epic and Scarlet FF35 Brains.
Of course, most PL lenses do not have a Full Frame image circle, so you will need to shoot in a windowed S35 mode.
aha...so....thanks....gotta save moooney...
btw.
i can buy a superduper modular epic rig and can keep a lets say scarlet s35 brain as back up in a case? and just switch the bodies, right?
Awesome that's all I had to hear. Can you tell us what resolution the 6K Epic will record in the S35 (16x9) window?
A rough calculation tells me about 4.75K no?
I think less - the pixels are bigger, so it'll be more like 4k.
It'll have less resolution than the Red One for the same sensor area, but the S35 area will be a bit larger than the Red One's.
All fine by me.
  • Thread starter
  • Admin
  • #9
Hey Evin.. great question, we will publish a more detailed chart down the road.
FF35 also enables full anamorphic lens coverage.
Ohhh... here comes the limitations. Monstro Scarlett can't take anamorphic.
I loooove anamorphic.
There goes my Scarlett. Thanks Jim!
...on EPIC only!
Jim
Well...I'd imagine that one could still shoot with anamorphic lenses on the full, not windowed, FF35 frame of scarlet and then just manually crop and unsqueeze in post if they felt like it. The sensor real estate is still there. Just sayin'...
then buy an Epic or rent one!!!
