Max mode
Grayton hevern
Active member
Can someone tell me what impact MAX mode is going to have on scratch,
Max mode is the default. B16 uncreased the quality and stability but as a result also decreased the framerates for Scratch a bit. Unchecking it lets it do an older mode that worked well for Scratch at half res high
I found the above information from one of the red guys on here, but does that mean with the max checked you are getting a better quality picture, because if it does you cant really ask a client to uncheck it to suit their post path, I have noticed that real time playback has been somewhat unstable of late on scratch, but I put it down to some bugs in the new version, is it more likely to be with the improvements in build 16. And what can I expect to see once I do my first build 17 conform or rushes playback?
