RayFrisby
- Dec 28, 2006
- Ireland / UK
- www.40ft.ie
III
Maybe I'll be pleasantly surprised when my new drives come in. In Final Cut, I was getting the orange render bar on 1080P 10bit uncompressed with no option to switch to high quality playback. Yet my RAID seems plenty fast to play it. So, could be the drives were just bad or something else is going on. If I can do 1080P uncompressed with some room to spare, I will be a happy camper. Although, I'm sure my mac isn't. A lot of heat in there with 5 drives running. Eventually I'll put buy a big, fast external RAID. But for now, this will do.CalDigit RAID card is the best RAID card right now for the Mac. ...Or at least it is if you don't need full SAS connectivity. Don't buy the Apple card -- it sucks. I have an Apple RAID card for sale, but I haven't found anyone I dislike enough to actually sell it to them.
There is nothing wrong with running a RAID-0. In fact, for a 3-drive RAID configuration like this, I would recommend the RAID-0. This is how I have my Mac Pro workstations configured -- a single fast drive for OS and applications, then a 3-drive RAID-0 for workspace. To be honest, a 3-drive RAID-5 isn't all that secure and I have seen them fail before where replacing the faulty drive still could not allow for full recovery. You also lose a significant amount of space and performance by going to a RAID-5 on a 3-drive system.
If you want something a lot more secure than a RAID-5, then move to an external RAID-5 or RAID-6 with 5 or more drives. Or get the CalDigit card and do the boot drive w/ 3-drive RAID-0 internally and add another 3-drive RAID-0 externally, that is a mirror of the internal RAID.
The real consideration here is your backup solution. Have a good backup plan in place and stick to it. Then you will have no fear of your RAID-0 going down. If it does, and more than likely it will not, you can simply replace the problem drive and rebuild from your backups. I have to disagree with Ron in post #2. I would never consider a 3-drive RAID-5 to be secure enough to not have a backup solution.
With a fast 3-drive RAID-0 (3x1TB 7200rpm) you can just about grade 2K DPX sequences in real-time. Or you can on a 3GHz 8-core Mac Pro. You take about a 30% decrease in performance by going to RAID-5. But either configuration (0 or 5) will be plenty fast enough for working with R3D files, transcodes, renders, ProRes, etc..
Should I use the AJA codecs? I've been wanting to try out gluetools. Maybe it's time to do that.1080p uncompressed 10bit is a dog if you're running it through the standard QT codec for that. I've tried it here and it chokes up the internal RAID. The external CalDigit HDPro that handles 450MB/s does better and can more than handle the data rate, but even the 3.2GHz 8-core doesn't like it. It also doesn't help that most of QT and FCP are still primarily resident on a single CPU. I actually get better performance on DPX sequences wrapped to QT with GlueTools.
You will have performance spikes and drop-outs with most any drives on a smaller RAID volume. Best way to even out performance is a larger array. But if you still see the effect with 5 drives, you may have something else going on. I would suspect power or heat issues to start with, not necessarily the drives themselves.
Just one last question Jeff, do you think I would be better investing in an external raid or do you think the internal 3 Disc setup would be sufficient for 2K work with Cineform ?
Hi I was wondering if anybody can help
I have a medium/large sized project coming up and was thinking of re equipping my pro mac for it. (2.66ghz dual dual with 8gb Ram)
If not I will look at using external storage via fiber channel or raid arrays.
Regards
