Jorge Díaz-Amador
- Apr 26, 2007
- Portland, ME
- www.cinematechnic.com
I currently have a set of first generation Zeiss Super Speed primes undergoing complete overhaul. Since I have been told by West Coast (US) lens techs that these are called "B Speeds" (I always called them Mk. I Super Speeds), I will refer to them as first generation Super Speeds.
This set is in the best mechanical condition that I have ever seen for these type of lenses (I've been working on this type of lenses for 10 years). Once the refurbishment process is finished, they will be in excellent condition and ready for years of use.
Details are as follows:
Distagon 1,2/18mm T1.4
Distagon 1,2/25mm T1.4
Distagon 1,2/35mm T1.4
Planar 1,3/50mm T1.4
Planar 1,4/85mm T1.4
Despite the fact that these lenses are rated by Carl Zeiss as T1.4, the first three lenses are f1.2 which means they will have the exact same depth of field as the T1.3 Super Speeds. This is because they are the same optical design (but with a different iris design).
The 50 and 85mm are a little slower at f1.3 and f1.4 respectively. This is due to the fact that a large enough rear element for f1.2 would not fit inside the ARRI Bayonet mount. These two focal lengths were re-designed for the T1.3 series.
The difference between T1.3 and T1.4 is miniscule, and what is really desired on a digital camera is the f-stop which determines depth of field.
These lenses will be fitted with permanent PL mounts, focus gears and 80mm fronts.
With second generation T1.3 sets selling for nearly $40,000. USD, these lenses represent an opportunity for significant savings.
This is the first set of 35mm format Super Speeds that I have had in stock since 2004, and it will likely be the last for a long time. Express your interest now, before they are gone.
Please PM me if you are interested.
