Lost my LCD output
NateWeaver
Lost my LCD output tonight...
I was trying to boot with the key combo to view hours...and I mis-remembered it. I booted with "Exit" and "Undo" (now realizing the correct combo is Undo and joystick down)
I caught the back LCD say "Devboard forced on", and then proceeded to boot normally. Except no Red LCD out.
Since I can't seem to search on "LCD", I can't find any of the threads where methods to get the LCD working again are listed. I've tried:
1-Cold boot, from disconnecting power and waiting
2-Disconnecting power and pressing power button 8 times
3-booting with all periphs disconnected
4-Reloading build 17
5-All combos of 1 thru 3 above
Is this Devboard mode still enabled and that's my problem? If so, I'm not seeing any confirmation of such, even while booting.
Anybody have a clue?
Have you tried booting again with the same keys pressed as made the switch the first time? Trouble with these things, what's the key sequence for "boot it normally thank you"?
Arg. No suggestions?
I contaced Red before I had to leave for the day, and no response from them from the VM I left.
