George A.
- Apr 11, 2007
- New York City, NY
- www.eastrentals.com
Hi!
As you know, the RED Universal Mount (http://www.red.com/store/601002) fits only on 19mm rods. However, many people are using the 15mm rod system (100mm apart - Arri studio standard) with their REDs. Many of them cannot find a viable, alternative solution - there are really no universal mount equivalents for the 15mm rod system, at the same price range (the ET top mount and other products are much too expensive for this purpose). I know Jeff Kilgroe wanted to make one at the same price, but changed his mind.
I have an idea.
Why not use the cheap RED Universal Mount itself?... Someone can design two very simple "Shoe Spuds" (adapter sleeves) that can go into the Red Universal Mount and convert it for 15mm rod use. Of course, these adapter sleeves would have to be off-centered inside, but it should be very easy to do. I tried it and the 15mm rods at 100mm apart fit physically inside the Universal mount, but the rods are not perfectly centered; all we need are two off-centered shoe spuds inside to really lock it in the right position (after the correct measurements etc). Check the drawing I made.
I already wrote to Jim at Monstercine about this but so far no answer. His company already produces Shoe Spuds converting 19mm to 15mm (at $33), but they are centered. He would be the best choice to do this - it shouldn't be too hard to make them off-centered. If not, maybe someone else can do it and make a profit? I'd be the first to buy a few.
Many people are looking for a solution to this so I am positive this would be a success. What do you guys think?
I have an idea.
