Justin Chin
- Aug 15, 2008
- Oakland, CA, USA
- www.infinitemachine.com
While testing the Red Cam (build 16 v3.2.5) for a shoot the camera suddenly "initialized" at random times.
In an effort to check on the problem performed a soak test with the camera turned on by itself; no lens, AC power, no drive and no interaction. Nothing for 20 minutes.
Then added a red drive. Nothing for 20 minutes.
Added a lens, 40 minutes later the camera repeated the problem with "INITIALIZING" burn-in on screen for about 1-2 minutes. The camera then will returned to normal but the LCD Pro had a blue tint. That blue tint goes away if you unplug / replug the LCD connector. The blue tint is what keyed us in to the issue as the camera might have done this without us attending it (around 4 times during our tests).
At first we thought it was a faulty power switch; you don't have to fully press in the switch to turn off/on the camera - i.e. no click sound. But I think the soak test eliminates that cause.
Also, I don't think adding the drive or the lens during the soak test is any evidence to their contribution to the problem.
Otherwise the camera works very well, and it only did that while we where sliding the matte box on the rails, or simply just by itself.
Any ideas?
Any ideas?
