Mark L. Pederson
REDuser Sponsor
Can you define EXACTLY what you need in two sentences that you do not have now?Now that the SDK is out, I pray that we finally get what we need.:meh:
Emmanuel
Emmanuel
This did not happen at all with DSLRs.
Care to give me an example of people saying a Canon or Nikon DSLR is bad based on results with crap RAW developer?
Ibloom,
Be sure I don't have anything against your great tool.
Just wondering why the biggest player in postproduction (Autodesk) still promote DPX instead of the use of native 12bit REDcode?
But you probably got an argument saying R3D is not a way to go for postproduction...
Even so, it's faster/easyer/cheaper to confom and CC R3D with Scratch (last job I did we used the native R3D files) and it's a pitty that the actual SDK don't permit other manufacturers to be as competitive as Assimilate.
Ian, I hope this was not misinformation.
Patrick
One program that can color correct and transcode, with audio in the most time efficient manner and can understand an EDL from final cut or avid. One that can batch looks and easily open multiple files as well as set in/out points for each.
We're sorta on the wrong end of the technology. DV works just fine by now...
I work with a lot of Post Houses over the world and I don't know one of them who actually uses a workflow hardware or software that benefits from the SDK at this given moment. I'm not including the ones who has Scratch in their workflow system.
(All of them has developed successful workflows but they're all work around)
Which NLEs edit HDCAM or HDCAM SR natively?
Graeme
Having worked in post houses for 20 years, EVERYTHING is workaround to some extent.
This whole thread reeks of someone who doesnt understand software development getting information from people who understand it even less.
Graeme
