Giancarlo Bianchi
Don't buy hard drives and especially do not buy your RAM from Apple unless you like to throw away lots of money.
I found these on BH, Can anyone recommend Crucial technology Brand?
My preference is (2) ribbon-attached ATI Radeon 3870 HD cards.
http://www.macworld.com/article/133935/2008/06/radeon.html
Ribbon to attach two together comes in box. I'm not 100% positive that Mac OS 10.5 will support dual attached cards.
Since these are not available from Apple, just pick cheapest card and then order two of these for around $200 ea. from Amazon.
http://www.amazon.com/ATI-100-43592...1?ie=UTF8&s=electronics&qid=1223330966&sr=8-1
Just make sure you put both in 16-bit PCI slots. The Mac Pro (Early 2008) computers implement PCI-E revision 2.0 which support twice the data rate per lane as the PCI Express revision 1. Slots 1 and 2 are both x16 revision 2.0 slots. In my Mac Pro, I can run two cards striped because only one channel can be set to 16 bit.
http://support.apple.com/kb/HT2838
-shooter
Has anyone seena performance boost in Color using this setup? Has anyone gotten it to work in 10.5.5?
With Color now supporting Native Redcode this has become important.
Hi,
I have looked at the ATI 3870 card on OWC:
http://eshop.macsales.com/item/ATI Technologies/100435928/
AND I have searched to see if I can get the same card where I am, but only thing I found was "SAPPHIRE HD 3870 Blue II D4 512MB."
I have attached a photo of it, and it has Angelina Jolie's Tomb Raider character print on the card.
Is it safe for to buy this Sapphire HD 3870 one instead of the OWC one, or should I get it from OWC?
Thanks,
Does anyone knows if these can work on a mac?
By the specs it appears they do. I was going to Import OWCs from macsales, as Jeff recomended, but finally I think I found some affordable modules in Spain.
Thanks in adavanced.
The card from OWC is for Mac & PC. The one you found is probably only for PC. Look for one that is for Mac & PC.
