Just out of curiosity -
has anybody ever tried a pinhole lens? Would that work in principle?
Yes, it would work. Of course it would be difraction limited, so don't expect Master Prime glass speed or quality :biggrin:
there are some drawings for this in one of my older posts...
I guess this is what you have been looking for:
http://www.northlight-images.co.uk/article_pages/Canon_1ds_pinhole.html
Well, it looks like the PL lens shortage problem has been finally solved! :biggrin:
Sure, as long as you don't mind running 30 seconds per frame instead of 30 frames per second. (Slight exaggeration, but you get the point).
Dave
I couldn't find the drawings that you mentioned in your other posts...
could you post a link if possible?
thanks in advance...
...and it can't get any cheaper than a couple of toilet paper tubes (for a zoom - you can get a prime with just one toilet paper tube).
These, if you want to make a 10mm for S35 the PL hole is too deep, so I show a two lens four element retrofocus deep-focus "pinhole" lens drawing also there, i.e. to clear the PL hole so as not to vignette.
http://www.reduser.net/forum/showthread.php?p=222321
If you are making a long lens, you can use two lenses in a symmetrical design one on each side of the "pin hole" outside facing out and inside facing in, that cancels the lateral CA so you can get a good image from like 75mm to 1000mm if you go f/11 to maybe f/32, from f/32 to f/64 the image may get a little soft, past f/64 maybe too soft. Two telescope lenses would work.
You can also make a Petzval like lens if the rear lens is shorter in focal length, then you might get sharper results.
