Axel Mertes
Hi Jim, RED Team,
I have a question that *may* sound irritating in first place, but I do see a real use for it:
Do you consider to create (kind of artificial) RED CODE RAW images from RGB footage?
With the upcoming RED RAY system as a distribution solution for us film makers, its a great option to spread 4K RAW playback files. But for most of us its *extremely* unlikely to spread our source RAW footage. Instead, its more likely we start to grade it, add VFX and titles etc. We do many processing steps that would - at best - end up with a 4K RGB sequence. Playing 4K RGB sounds not very likely to happen via RED RAY, or is that on the list too? Wouldn't that need 3 times more disk space anyway?
So I think it is a valid idea to consider to convert back from 4K RGB to 4K RAW with a final project just for distribution purposes. It would mean RED CODE RAW would be end-to-end. Right now its only ingest. RAW saves 1/3 disk space upfront. The rest of the compression is comparably mild. I am not sure if I would prefer kind of H.264 compression scheme over RAW deBayered.
Or are you working on a GOP based RED CODE RGB 4K or something like this?
How would be the distribution path for Indy film makers - how can they share composed and manipulated 4K movies they made? Hopefully we will not be stuck with HD or 2K then...
Would be interesting to read some comments here
Thanks in advance,
Axel
Thanks in advance,
Axel
