Matthew Greene
I think some people have tried to use Bayer in one exposure per frame to scan with, the J&K scanner seemed to work that way, maybe some others. Not all labs let you into their scanner room to see what they are using, and there is pressure to run everything as fast as you can, so no commercial scanner is going to make 27 exposures per frame, even if you can see a difference.
I think some 2 1/2 sensor backs have been used in some labs for special projects, and those must be Bayer?
I was talking with a guy in a LA lab who wanted to use a Nikon DSLR and start a scanning lab, so people have the idea that one exposure is enough. My tests show that you can get an images, but the color is not as good as separations even with extra software processing, like they say, "garbage in, garbage out".
The one good thing about the Canon XTi for making seperations is that it has good dynamic range on the brackets, and I can hold both ends of most dense negatives in three exposures per color. But its noise level is way to high and with 27 exposures per frame it will break after a few thousand feet scanned if that much. So DSLRs are not a good idea for anything other than testing your projector, lens, and light house, at some point getting a good monochrome camera will probably be on the purchase roster...
First off I want to clarify I'm discussing scanning negative stock below, (not reversal). There are numerous issues when using a Digital SLR, one is the lifespan of the mirror shutter, you'll be lucky to shoot 100K frames before the DSLR mechanical shutter dies (unlkess you use a system with a shutter lock), another is inconsistency between frames due to the temperature buildup on the sensor which will cause noise and color variations between frames. One more issue is speed... yes DSLRs can burst several FPS but then have a wait before being able to burst again. I've been there/done that. I've also been lucky enought to either do some dissection and/or maintinance on the Spirit Datacines and Rank telecines and even the old Kodak Cineon systems in the past and took in all the good and out filtered the compromises. Start with the perfect light source, get as much usable image mapped on the sensor. By this point the image should look good. All post processing be it on a DaVinci, Pandora or Software based system should be limited to minor cleanup and artistic decisions as far as I'm concerned.
I want to reiterate that multipe exposures for capturing the full latitude of a negative are not needed in negative film... The whole latitude of the film lives in a very shallow density range. The magic comes when you try and expand that to data world without leaving banding and gaps in gradations hence the desire for high bit depth imagers and processing. If using color separations on Monochrome images, yes, you want at least 3 exposures for the primaries plus perhaps the option of some additional IR/UV (plus a special pass I've been playing with) exposures for masks as post processing masks for artifact removal. When talking about a S8 or 16mm scan from a bayered sensor such as RED's I don't feel that there's much compromise in even doing a single pass when it comes to color rendition and latitude. There are other reasons I would do multiple passes in those scenarios but I'm keeping them to myself at the moment till I experiment some more.
P.S: I personally find the 27 exposure approach a bit eccentric although maybe it's necessary in some situation I've yet to come by.
