ralf.luethy
- Apr 20, 2007
- Munich + Feldafing, Bavaria, Germany
- www.field-of-view.com
I noticed that the RED 19mm Base gets stuck when I try to slide it one the dovetail-connection of the SKATER MINI (P+S Technik).
I got the regular ARRI base as well, (but that of course is "off-centered" so the it doesn't work with the red one if you want to use a matte box set on the 19mm rods) which slides on smoothly - so I figure it must be slightly wider than the Red/ET one....:sad:
A manufacturing issue??
