bongobongo
New member
Here is what I want
Here is what I want
One large sensor preferably 24 * 36 mm
The whole sensor area to be used for Stills as well as full width of the sensor for video 24P, 25P, 30P, 60p ... in 1080, 3K, 4k and eventually 120p in burst mode.
Now in order to make it support ONE NEW REMOVABLE ULTRAFAST, ULTRACOMPACT, "LIGHTWEIGHT" GUERILLA RED ZOOM LENS, as well as some fixed RED lenses, more DOF (yes more), why not make it so it uses some smaller part of the 24mm * 36mm sensor ... how much of the sensor... well it would be nice not needing a truck when you move this tool around... why not use an area equal to super35mm, same size as the RED ONE.
I would like to see the RED ultrafast zoomlens for this puppy to be more wide than tele. If compared to 35mm photo, then I would rather have
a 20mm - 150mm lens than a 30 - 200mm lens. For those wanting more tele, then make another zoom or some fixed lenses.
Then we have the best of both worlds....
Full 24 * 36mm sensor size for photography as well as for some 1080, 3k and 4k video and shallow DOF.
Super35mm with support for RED zoom and fixed lenses, not so shallow DOF, RED RAW, ultrafast, compact video beast.
All in one compact unit, with support for different DOF...... then buy RED lenses and/or Canon lenses depending on what you want to shoot.
When in video mode one should be able to choose between RED RAW and another more compact format.
I want it to come with a small sized battery for photography and some video shooting.
For more heavy video then it should be possible to hook up some optional batteries.
To compete with the small big (Nikon, Canon, not the big big guys like Hasselblad, Phase One) guys in stills mode it has to be 24 * 36... period.
It should produce as good stills as the 5D Mark II will, at least in the 50 6400 ISO range.
If the above for stills then they should also support canon EF lenses as well and if possible both Canon and Nikon lenses. If it supported EF lenses... then many of these lenses has IS (image stabilizer) built in...
AF and MF has to work flawlessly in both stills and video mode.
For stills it need X-sync for those mega studio flashes as well as a flash shoe on top of it.
One high res display where you can zoom in to check focus.
And absolutely mandatory, this display should be flippable so you can actually use it in different shooting situations where your eyes do not have to be right behind the camera (canon wake up). Please let this be an OLED display with antiflare surface so we can use it outside in all weather....
For stills it has to shoot RAW (why not Adobe DNG format), and if possible be able to shoot JPG in parallel.
Full weather sealing..
Less than one kilogram.. (body only)
A lightweight handle so you can hold it in your hands when shooting below your hips, standing still, walking or running (canon do you read this).
Please make this smart, so when not needed I can push it into the body, and when I want it I just pull out the handle.
Of course support for XLR mics in one way or another, maybe default the small way... and optionally a RED breakout full size XLR box (premade tracks for this breakout box please so I do not have to use tape)
Headphone terminal.
Keep up the heat RED team
Here is what I want
Headphone terminal.
