TedRed
"The Mouth"
- Dec 30, 2007
Hello,
I've been on quite a travel tear as of late, but trying to stay local to focus a bit more on more training presentations in LA and more online training tools.
The original mythbusters is still valid as a workflow, but as many of you know much has changed in the camera that effects the performance in post.
Where months ago on the fastest Mac tower we were able to do 2k QT ref movie editing in FCP quite easily, we have been in a mode where most have been relegated to using the 1k QT ref movies to cut - (which are quite fine for most long form editorial, feature films, TV movies, etc. where there is a lot of footage, and no desire to transcode - there is a big benefit to dragging the files into a timeline and cutting)
I spent some time in London a few weeks back, with a group cutting a RED shot horror movie all with the 1k (_M) ref movies and they were loving it.
As many of you know, if that realtime edit mode is not enough quality, or you need true "greenline" performance for editing in FCP, then you take your 2k (_H) movies and render them to ProRes, and cut with those instead, you have the option of using RedRushes or the Log and Transfer plugin to to this.
And - There is some good news recently with the latest Quicktime codec that takes those renders from the 2k (_H) movies and renders them to ProRes at Apx 3:1 again on a single Mac Tower, so it's manageable for both short form and long form projects.
This new codec gets us very, very close to realtime performance again with the 2k QT ref movies, to the point on an Octo Mac that if you are OK turning the dropped frame report on playback message off, you can edit with the 2k files again instead of just the 1k files (1k on most Mac systems should be a no dropped frame experience)
If that doesn't work for you - them move to the ProRes route, take the processing step and use those files.
Hope that helps a bit.
+ Ted
+ Ted
