Does anyone have problme using AV Power from the Charger?
Gabriele Turchi
New York City
I just got my RED,and the AV power input from the charger it doesn't work..
Actually work once in wile..
Got another charger from RED... same thing
is this a popular problem?
G
Yes, this definitely works. Brent thinks it's an issue with the cable, not talking to the charger properly. The voodoo trick with the battery somehow fools the charger into working.
It doesn't work for me...
Should i remove the battery while the charger is on?
G
Gabriele-
We had the same problem. Try attaching 2 batteries simultaneously to the charger, then turn on your camera. This is what works for us and once the camera's powered up, you can safely remove the batteries and the camera should stay on.
Thanks!
I think i found my solution:
Connect the Camera to the Charger (both turned off) ,turn on the charger , press 1 time the start button on the camera , remove the cable from the camera , wait a few seconds , the AV light on the charger will turn on , connect the Camera again, Turn On the Cameras.
This works for me (and without attach battery...)
G
