Nir Shelter
- Jan 27, 2008
- Age
- 47
- Sydney Australia
- www.datashelter.com.au
I would really like to see an option to choose a naming scheme for the clips. To the best of my knowledge this is not possible currently build 18 maybe....?
I.e time of day based adding on a set of digits derived from the currant time of day to the end of a clip name. Or a successive count adding a digit to the end of a clip name and then adding 1 to that number, starting over when reset by the user. Or a unique ID for each clip based on camera serial number, metadata or project name.
Reason being that if you format one mag using a specific slate and reel number and then latter during the day format another mag using the same slate and roll number the clips will have identical names. For off line and on line work flows this could be a problem.
Can this be done or can this be made possible for future builds?
