Chris Parker
REDuser Sponsor
- Jan 30, 2007
Okay, I read the step-by-step on avid.com/red and I liked it.
I wanted to post an official thread with my needs for a job I have to do next week with a very short delivery window. Since I have not transcoded .r3d into an AVID codec, i would love someone to give me the AVID for dummies solution for my needs on this particular job. The best way to skin this cat as it were.
I will be shooting a live sports event. I will need to take selected clips from this event and colorize them (in red alert or redcine, my only two options), then export into DNxHD to deliver to an AVID editor. I will only have two days to get this done, and to be honest, I am trying to find the simplest, most fool-proof solution here.
One note is that I will be shooting mostly 2K at 120fps, with a 23.98 base rate. As these are for broadcast, I am assuming they will (at some point) have to be put into 29.97. Do I do this in the conversion part of the workflow, or does the editor do this at the output portion.
Also, there will be no conform. My goal is to get the editor the AVID files that will then be considered the final. No offline here, then conform, then colorize. They will use the clips I give them to go to air. They will want the best quality possible, for broadcast. I am assuming DNxHD codec will be fine.
Man, if they were cutting on Final Cut, I'd be set. I would just export from either REDCine or RedRushes with my color settings to ProRes and deliver that. Done. I am looking for the equivalent solution in AVID-land. Will be great to learn this and get one under my belt actually....
Any advice? thanks.
Any advice? thanks.
