Steve Sherrick
Multi-Format 2 Channel SDI Signal Support
(480i, 576i, 720P, 1035i, 1080i, 1080P, 1080PsF)
· Input - 1 HDMI, 1 DVI, 3 BNC (Analog), 2 BNC (SDI)
· Output - 3 BNC (Analog), 2 BNC (SDI Out)
· LCD Resolution -1920 X 1200 (16:10)
· Dot Pitch - 0.27mm
· Color - 16.7M (true), 24bit
· Contrast - 800:1
· Viewing Angle - 178°
· Power - AC 100-240V / DC 24V
· Power Consumption (Approx) - 112 Watts (AC) / 73 Watts (DC)
· Weight - 29 lbs
· Dual-Link (4:4:4 and 1080p60 compatible) - option
This monitor is less than 5 months old with low hours on it. It has the ND glass filter option which can easily be removed if so desired. This is a great monitor for studio but could also be used on set. It's one of the best under $10K monitors you can get.
I'm asking $6500 for the monitor. Serious inquiries only please.
· Contrast - 800:1
· Weight - 29 lbs
