Hi,
I'm sure you have all read multiple "backfocus threads" but I think this one is different, so pleas stay with me...
Saw that the wide shots were kind of soft after our last shoot, so I decided to re-check backfocus.
I used a 16mm lens @ 3meters with a Siemens star as the target. and sure enough back focus was a little off, so I do the following:
a) Unscrew the two locking screws on the (PL) mount collar (which took some effort because they were TIGHT).
b) Set the lens @ 3m
c) Turn the collar to achive best focus.
and now it gets scary!
d) Tighten the two locking screws (not crazy tight)...
...and now the focus is off!!! - way off!!! - I reajust the focus ring on the lens, and best focus is now about a meter off from the 3 meter mark that was best focus before tightening the locking screws.
Thinking that I'm doing something wrong, I repeat this process more than 10 times - but the conclusion is clear, tightening the locking screws changes the backfocus adjustment - by quite a bit.
Slowly I realize that my only shot at getting correct backfocus with the screws tight, is to dial the collar to a point where focus is quite a bit off with the screws loose, and then thighten them - check how much focus is off - open the screws, and "guestimate" the needed correction - tighten the screws again, and after 10 or so iterations of this, I arrived at what I hope is a correct backfocus setting.
So, what's going on - is this the way it is, or is something wrong with our camera?
Can someone please shed some light on this?
Jack
P.S. And before you ask, I was very careful to make sure that the ring did NOT turn while I was tightening the screws.
Jack
