David Newman
Christopher,
Thats what I wasn't understanding. So when we speak RAW we are speaking the cineform RAW rewrapped r3d. ?
I don't get that folder structure created "Express, HD444, Raw", I only get one folder created for the script I run. Batch to Express, I only get an Express folder created, batch to HD444 only the HD444 folder is created, etc. Is there another script or should I be editing one of the batch scripts to create the 3 folders simultaneously?
Also, I noticed Batch to Raw doesn't batch convert all in one root folder as express and the others do. It converts one clip and stops, has this been disabled for
Batch Raw?
Thanks again.
You would need a script that makes three directories. Which three? There are too many possibilities. I understand that some may want to batch both express and RAW or HD444 or whatever you need (up to you.) But by providing sample scripts is would be very easy to create, or have a batch that batches the scripts.
I just downloaded R2CFv155.zip and tried the BatchRAW on my underpowered home P4, and it worked fine, producibg a "RAW" path just like the "express" and "HD444" sample scripts (the scripts are all the same code, just with the header changed.) One possibility: if you aren't running Prospect 4K or NEO 4K, then you don't have a RAW license causing the RAW script to fail. I think you might need to update your R2CF tools and scripts.
