Can "Red" company do something ?
hiall
About the Redcine, I can't install, even many people can't either.
I think there should be something wrong with the program. Is it possible the "red" software team work out a solution for this ?
I feel very frustrated for this !
MacPro Quad-core
Leopard updated
I am not the only guy couldn't install Redcine
http://www.reduser.net/forum/showthread.php?t=15972
I think the problem is only for Redcine since RedAlert and Redrushes both OK to me.
What I did is only download the application, extract to dmg, and then open it , put the redcine.app into Application folder and double click it.
the screen blank for 2 sec, then return to the original desktop. After that, I found the Redcine folder in "Library" with only "Setting" folder inside.
tried all version from 1.0, all not working to me !!
TRY to remove anything you find in your computer named redcine
Especially in Library folder ,empty trash , restart , run it again ? maybe :excl:
Try going into Disk Utility and running Check Permissions...
This sounds like a permissions issue, possibly related to execute bits on the binary or similar.
Also look for messages in the log files -- check the "Console" program under /Applications/Utilities.
that sounds like you installed it on a non-admin account
try the same process you used but as an administrator and all your problems go away
I am the only user of my mac and I don't need to select account to login !
So I think I am using the administrator account ? right ?
If I post the log here , can you guys help ?
