log to lin
"log to lin"in the scratch what does mean? thanks
It is an inverse log curve used to 'linearize' a log colorspace image. Most film is scanned to a log colorspace DPX file, so log to lin is quite important. Some will use a log to lin monitor LUT, but I prefer to linearize the footage, grade it, then convert it back to log space as the very last operation.
log to lin is not useful for Red footage, as Red does record in log, even Redlog is, essentially, a linear colorspace.
regards,
John T.
First, gamma curves are not colour spaces!
Second RedLog is log - the curve is a log curve.
Linear means a straight line - neither video gamma nor log is linear
Linear is often abused and some people, who should know better, use it to refer to a video gamma. They are incorrect and they confuse people.
Graeme will now step down from his soapbox - normal service will be resumed presently.
I don't know what the log to lin in scratch does - perhaps Lucas would tell us precisely?
Graeme
Lucas, does "lin" in log to lin refer to linear light or video gamma - ie, what does it linearize to?
Graeme
So Lucas, what you're saying is that in "log to lin", the "lin" can be set to 1.0 and hence be really linear, or it can be set to 2.2 and only be linear to people who call curvy things linear?
Graeme
Graeme
Correct. :)
There is also another setting in the "Project Settings" menu in SCRATCH that sets Neg Density, which also affects this transform.
Lucas
Lucas
So lucas ,what does "de-sat" mean in your screengrab of zhe generic 3D lut interface ?
