Files greyed out in Log and Transfer Tool
Jochen Kunstler
Active member
I'm doing my first Red project and we decided to use the Log and transfer tool to render the Raw files into Pro ResHQ and work from them since maximum out will be 1920 x 1080 HD layed off to an HD CAM tape.
So I downloaded the red codec and the Log and transfer tool (newest beta version) When I open the tool in my project everything looks fine. I set it to Pro res HQ.
Now, when I try to open files in order to decide whch ones to add to the que, I see the folders (structure unchanged from the red drive), but the actual Raw files (and the QT proxies are greyed out).
What am I missing?
(I'm running FCP 6.0.4. and QT 7.4.5 on Intel 2 DUO core 2.4 Ghz processor with OS 10.4.11).
Dunno, it works fine here, but I'd suggest RA/RR anyway.
I might try that. C
an I preview and then only select my circle takes? Nobody kept a correlated log of file names and Scene/takes numbers. So I have to physically look at the slate to know which file contains which take.
I would like to avoid having to go into the proxy for each file to find out which take it is.
Jochen
What am I missing?
Any chance you have FxFactory 1.0 installed? If so, remove or update it.
