Nigel Stanford
REDuser Sponsor
- Feb 26, 2008
- wellington / new york
- www.rubbermonkeysoftware.com
Ok, here's another one... :innocent:
I love the idea of the false color / heat map feature, but I don't use it much:
The current one is something like this:
The current version is cool, it's not something that can be left on all day, unless you're taking powerful drugs...
What would be really useful is a heat map where only portions of the image that are clipping or approaching black get colored. A transparent heat map would look like this:
You really only care about the areas of the image that are clipping, or approaching black.
For other cameras, I have created a 10 bit LUT where anything over 1022 gets colored, and anything under 120 gets colored. The lower end number depends on your definition of acceptable noise. Ideally the user could adjust the threshold.
You can use it to judge exposure, basically open up until it's just about to clip. It's better than a waveform monitor because you can see exactly the part of the image that is clipping or in shadow, and it's right there in your face.
I leave it on all the time. In the day, if a cloud pops out of nowhere and is clipping, it's immediately obvious. I can just tweak the iris and it's gone. I also know that if I do so, I'm not going to underexpose - I can always make a judgement call on which part of the image is more important to preserve.
At night, I would make sure that a decent percentage of the frame was not colored, because I know that there's not a lot of usable detail in there. The amount of shots I've seen coming through post where nothing is over 20% on the waveform gives me chills. If the crew had had this tool on at all times, they might have thought twice about throwing a light in there
