Hi all,
I'm a bit of a RED newbie, and most of my experience is cutting on Avid MCSoft, anyway. However, I was handed a RED project to cut and so far I think I've done a pretty decent job. I'm getting ready to picture lock, and I need to make sure that I've done everything properly.
I have imported the QT reference videos from the .R3D sources into Final Cut Pro 6.0.4. I have been using the _M format.
HOWEVER, and this is probably because of my Avid training, I tossed all the reference dailies into a sequence, went to my sound reels, and synced up all the clips. Then, I set in and out points, created subclips (which look like miniature sequences anyway), and have been cutting with those in another timeline. (In Avid, after creating subclips I'd autosync them all, which appears to create new files that didn't give me any headaches.)
Is this going to be a problem? I need to eventually move onto Crimson, but when I've taken a peek at the XML files my project creates, it gives me a headache. The clips are listed twice, which I believe is problematic (but might not be).
I'm not sure how to proceed. Is this fine, or do I need to find some way to go through the whole project and actually use transcoded proxies? Do I use something like Clipfinder to fix my issue?
Also, an unrelated issue. Whenever I try to export the sequence to a quicktime video, I get the green bar covering a third of the frame. DVD authoring is not a problem, though. What gives?
Sorry for all the questions, but if anybody could help me out I'd greatly appreciate it.
