You can't send proxies on their own! Your editor won't see anything without the red footage. Actually, that's why the expression "proxy" is misleading, they are references for an on-the-fly transcode.
You'll need to transcode to any old format you can send around…
If your editor is on Final Cut Pro 6 then use a compressor droplet or Redrushes to transcode your _M reference files to Prores proxies. Then hand off the drive full of Prores.
