phibes
Active member
- Sep 16, 2008
we just got our Red One and started testing...
still there are a lot of things to be investigated but there's one problem that drives me mad: I try to get a proper signal into the Blackmagic multibridge pro for external monitoring. neither HD-SDI nor HDMI is working. The SDI-signal is somehow unstable, shows up for a second, then disappears a second, comes back for half a second.... it's the preview in 720p/50Hz. When connecting it directly to a HD-CRT it looks fine (for sure we used the same cables and connectors). Additionally I couldn't get ANY 1080p output to check if this is working better... In fact the multibridge provides HDMI input I tried this instead, but also without any luck... Multibridge input remains black on HDMI.
Someone here having experience with that setup (Red+Multibridge pro)? any suggestions what to check?
And what to do to get 1080p output? Does it work? How?
I'd appreciate every hint!
Red One Build 16 V. 3.2.5
