Clint Johnson
So there was this music video where they wanted the talent shot with visible light and then composited onto a background shot in infrared. We did some tests with the Red 18-50 zoom but it wasn't letting a lot of IR through what with it being T3 and all. There were some later tests with Superspeeds that the director was happier with.
Yesterday, out of personal curiosity, I decided to go out and test some more with my T3 lens. This time I was undercranking with the shutter set to 360 degrees so that I got:
1) A single frame per second at one second exposure got the most light of course but there were also some hot pixel and noise issues due to the longer exposure. The director of the video didn't want the band to look all creepified from the IR... but I make creepy work.
2) It looks like, with the Red 18-50, wide open at T3, the optimum exposure for light levels with IR is four frames per second with the resulting 1/4 second exposure. It is fast enough that the sensor noise doesn't effect it too much and slow enough that it doesn't have to be pushed too much in post to bring its brightness up.
3) Here is a shot at 24 fps and 1/24th second exposure. The scene was reflecting and emitting about as much infrared as you're going to see here - 1PM, clear day, >30 degrees celsius. While it would probably be usable at SD it is pretty noisy because it really had to be brought up in post.
If you are using fast lenses in the T1.3 or F1.2 range, on a really bright day, then I think you should get away with the 24fps at 1/24th. The optical optimum, but not the temporal optimum, would probably be at 8 or 12 frames per second.
Here is a link to InfraRED Testing.MOV that has samples of the three setting above. I didn't bring the undercranked footage right up to the project speed, nor did I correct it to actual speed- I adjusted it what I found the most pleasing to my eye.
