CameronORourke
- Sep 11, 2008
I'm (gently) pushing a new commercial project that I'm producing to using RED, mostly to get a nicer, cinematic look with the 35mm back and Arri primes, and to have a greater degree of control and options in post.
We are planning to just do a one-light correction in REDAlert, and then transcode to ProRes HQ at 2K, and edit, grade and master in that. (Not do a 4K conform.)
I have folks telling our production manager and director that the RED will require extra time in post, that RED footage never looks the same in post as what you saw on-set (I guess via the Rec709 tap on the camera) and that secondary color correction is almost always required to achieve an acceptable result.
They are saying that they often can not get skin tones and backgrounds, especially neutral backgrounds, to look right without a secondary color correction (with a mask or key).
They are comparing this experience against other, more traditional acquisition formats such as HDCAM SR and P2. Saying that these formats are more what-you-see-is-what-you-get.
Assuming that you have a DP that understand digital acquisition, and is not trying to paint a look in camera, this all sounds like Voodoo to me. Does this (the need to do extra color work on RED output) make any sense to anyone? Do anyone know what might be behind the comment about balancing skin tones?
