I have all of the above, but still it doesn't work....
regards,
Wim Coenen
Can you define "still doesn't work". See one of my previous posts about "green thumbnails" and "metadata columns".
Thanks,
Craig
regards,
Wim Coenen
Thanks,
Craig
with "still doesn't work" I mean that the L&T windows shows no clips. On a working machine, after you add a folder, the RED logo is in the L&T window saying something about adding the clips, and then all the clips show up. But on this machine, after you add a folder, the L&T window stays empty. No logo, no clips.
OK, this sounds like something is causing the loading of the volume to abort. I am assuming that you are using the same volume on the machine that works as you are on this one. If you wouldn't mind taking this conversation to email (private messages on this board) then I'll work on setting you up with a build that has some logging messages which may give me a clue.
Based on the descriptions it sounds like two very different scenarios (green clips vs. no clips at all.)
I'm on the latest FCP and QT. I think I do need more ram. I am on a Mac Quad.
The L& T red options are there. I opened up the Redfiles and all the screens are green.
I re-down loaded Red Cine, it now opens! But I tried to make a pro res but all it did is make a single freeze frame....
I feel like Charlie Brown.....
sigh........
sigh........
gunleik, this could be especially helpful in your case since you were successful on some systems and not on others. If you could do so for one that worked and one that didn't, maybe something will show.
When use log and transfer I select the directory. I get a list of clips, but the preview is grey and say can not preview this file. What am I missing?
Kevin
Sounds like the codec may be missing or [more likely] have an old codec installed. Try upgrading
to 3.1.
Just an asside should it take an hour to transcode 4 minutes of footage to ProRes?
Depending on quality and CPU: yes, it can…
L&T works here, but I prefer RedRushes.
Yeah, I have the L&T transfer window open, and using the add volume (top left button).
I'll check adding the RDM folder when I get back in the office again and see how I go though- have a feeling I would've tried it though.
