Chris Nuzzaco
You have to increase the total amount of light when trying this though, correct?
All that cutting out the red and green does is give you an indication that you need more light to get a good exposure. You can't just filter out red and green and expect blue to get less noisy - you actually have to increase the amount of blue there by adding light wattage. Otherwise, you'll be cranking up your digital gain.
Yes thats correct. I figured it would be a given. As for needing more light, its just life. No one ever said great cinematic images came cheap or easy.
There is a technique however that no one ever seems to mention though... You could design a bayer filter sensor that has the over sensitive channels photosites dies mixed with ND (much like color correction ND gels, for example). If you took this route, you could balance each channel individually without causing global light loss. The sensors sensitivity would go down, however, it would be the most sensitive you could possibly have it for shooting under tungsten light and not suffer blue channel noise. This is all due to the channel based filtering, instead of global filtering... As of right now, it seems (I can't say for sure) that Red has designed their Mysterium sensor in this manner, but balanced it for daylight.
Hope that helps!
