Adam Glick
- Jan 3, 2008
- Austin, TX
- www.boxxtech.com
agreed - very impressive for an early beta
1) how does the debayer quality compare to REDCINE Redalert or the proxies?
2) Will we always have to re-import the footage when we change the R3D Global settings? that would be a pain for offline/online editing.
I am very impressed too,but
I have to say that even if we can work at 1/8 and render out at full res (no proxies edl etc....) , i think that a 1/2 res of 4K realtime playback in premiere is something that we really need...maybe not in After effects , but the timeline of premiere...just the cuts etc...
Try to figure out a editing room with the clients that want to see the ruff cut....you would show them at 1/8 res in fullscreen...????
1/4 High in a 720 or 1080 project looks pretty good, IMHO. That's what we work on for realtime in SCRATCH, as we don't have a Skulltrail or Nehalem system yet.
What do you mean in a 1080 project...?
Actually 1/4 of 4k 16/9 is just SD and not HD....(2304/4--->576)...and also i am not even sure that at the moment could even playback that in realtime...
G
PS: I thought that Scratch was GPU "dependent" ... i think have a Quadro FX 5600 is more important than have skulltrail...right?
G
In SCRATCH (like in REDCINE) you choose timeline (construct) size, in Premiere it would be the project size. This can be 720 or 1080, if you work with a broadcast HD monitor. Of course, if you monitor in SD, make a SD project. Then set Quality to 1/4 High and your material to Fit Width. Sure it's not mathematically HD, but its a pretty picture even so. And your color correction will look the same.
It will playback realtime on a octo-core.
Fred
... i think that a 1/2 res of 4K realtime playback in premiere is something that we really need...maybe not in After effects , but the timeline of premiere...just the cuts etc...Try to figure out a editing room with the clients that want to see the ruff cut....you would show them at 1/8 res in fullscreen...????
Approximately 99% of network television programs, and at least 80% of features, are cut in standard definition, using 14:1 compressed Avid OMF files, and have been for some time now. They don't seem to have any problem working in that format, and for the most part, they don't feel they "need" HD at that point in the process. I don't know who your clients are, but I can almost guarantee that they're not any more demanding than executive producers of network television programs and directors of studio features.
Just thinking out loud here.
Absolutely true. At high end post houses in Oslo today, you pay more to finish a commercial at HD resolutions too. Most commercial jobs destined for broadcast are finished in PAL 16x9. 35mm is usually scanned 2K though, but that's just for grading. The grading suites output PAL frames as DPX to finish off in smoke/flame.
If you are going to deliver in SD, it's smart to monitor in SD. Easily forgotten with all these 4K files everywhere...
F
You are right and I am right.Come on Guys...
What you saying is true , but things are changing...35mm scanned in 2k and than down res to SD for avid editing as always be done because there was not enough by the editing workstation...also HD tape was more expensive , the 50' plasma was not even real , the HD monitor was 50000 $...etc...
Now we have a 4k camera , the files are ready (i mean digital) to be edited in 2k and there is enough power too...
Why in the August 2008 we should set up an SD editing system?
Also not everybody here have the RED for Tv finishing ,also someone like also edit in a 50" plasma screen ,
Cineform is showing the possibility to edit 2K in realtime under premiere,
I am just saying that adobe should do the same with R3d (but it seems that Rd3 is more complex to decode )
Anyway i am sure they will do as much as they can , i am just saying that they should keep going to have that realtime playback at 1/2 res (actually HD should be Ok but as i have understood the RAW system works dividing by 2 every time ....)
I agree that it should be interesting if any plug in for premiere should work with R3D files (like color Finesse)or if they need to be updated for that
G
Unfortunately not. It's part of the plugin.BTW, does this resolution trick work with all footage (setting to 1/4 res then resetting to native before export)? I have had trouble scrubbing through 1080p PHOTOJPEG footage on my PP timeline lately.
Completely awesome! Thanks to the Red Team and the folks at Adobe!!
