RedCine hangs on launch
Greg Derochie
Active member
www.formationfilms.com
I've read that others have had this issue, and I've tried trashing the redcine folder, reinstalling, etc, but nothing seems to work. The Redcine app hangs on launch without reaching a splash screen or anything. Any thoughts?
Macpro, OS 10.5.4, QT 7.5, Redcine 3.1.2
Logfile?
Sounds like an incompatible graphics card to me.
Lucas
Try this... Go to Utilities and open the Directory Utility. Click on the lock and authenticate. Under the Edit menu, enable the root user. Assign it a really good password (although you can disable it later). If you have automatic login, disable it in the System Preferences (you shouldn't have automatic login, anyway). Not good. Now, logout and then log back in as root. Open RedCine. If it opens up without crashing, you have an ownership and privileges issue with your ID. If it still crashes, then you'd have to troubleshoot further. PM me if necessary.
Good luck!
The log file should be in one of the folders within /Library/Redcine. There are four folders in there, I believe. Fish inside these for the log file to send out to Luki.
Here it is:
18:44:06.00 INFO : ---------------------------------------------------
: Redcine - [Build: Jul 9 2008]
: Log started(3): 11-08-2008 18:44
: \\Greg's MacPro\'/Applications/RedCine.app/'
18:44:06.00 INFO : Darwin Version 9.4.0 (i386)
: 8 CPU's: Intel(R) Xeon(R) CPU E5462 @ 2.80GHz
: Timer frequency : 0.00 MHz
: Timer resolution: 1 ms
: Physical memory : 2049 Mb
18:44:06.00 INFO : Memory setup:
: Available : 1256.984 Mb
: Frame heap : 683.984 Mb
: Proxy heap : 128.008 Mb
: Image heap : 48.008 Mb
: Total size : 860.000 Mb
: SMP Initialize : 8-way multi-processing
18:44:06.02 INFO : REDCINE 3.12 started
18:44:06.12 INFO : ===================================================
: Screen configuration
: Resolution : 1920x1200
: Frequency : 60.0 Hz.
18:44:06.12 INFO : ---------------------------------------------------
: OpenGL Context setup:
: OpenGL : 2.0 ATI-1.5.28 (ATI Radeon HD 2600 OpenGL Engine)
: GLEW : 1.5.0
: Frame buffers : Available
: FP textures : Available
: Fragment Program : Available
: Occlusion Query : Available
: ARB Shading L1.0 : Version 1.20
: ARB Shading Obj. : Available
18:44:06.12 DEBUG: TX PROXY: Texture proxy extension not supported..
18:44:06.12 DEBUG: PB: PBO Readback buffers not supported...
: OpenGL Framebuffer configuration
: Framebuffer : 1920x1200 (Double)
: R,G,B,A : 8,8,8,8
: Depth,Stencil : 0 0
: Accumulation : 0
: Blend Color : Supported
: Separate Alpha: Supported
: Blend Min/Max : Supported
: Texture info : 4096x4096 (Max. RGBA8)
: Texture rect : 4096
: Format buffer : 64 MB
: Texture float : Available
: Packed floats : Missing
: Multitexture : 16 units
: Non Power Of 2: Supported
: Mipmap gen. : Supported
: Texture clamp : EDGE, BORDER
: Setup Server components..
: XML Library (2.6.11)
: IO Alignment configured: 8192 Kb
18:44:06.13 DEBUG: Assimilator: Load image IO format instances.
: Font manager..
: Freetype 2.3.6 initialized
18:44:06.81 INFO : ---------------------------------------------------
: >> READY..., SET..., GO !
18:44:06.92 INFO : Initializing Audio setup:
: 2 : 2 Channels, Apple Inc.: Built-in Output
: 3*: 2 Channels, Apple Inc.: Built-in Line Output
: 4 : 2 Channels, Apple Inc.: Built-in Digital Output
: 5 : 8 Channels, Matrox Electronic Systems: MXO Audio
18:44:06.93 INFO : Loading system settings
: Read from: '/Library/Redcine/Settings/System.reg'
18:44:06.95 INFO : Select user(1): 'gregd'
18:44:06.96 INFO : Instanciating project: 'Session_1'
: Load settings from: '/Library/Redcine/Project/Session_1/Project.reg'
18:44:06.96 INFO : Media configured base directory: '/Users/gregd'
18:44:06.96 INFO : Initializing FX setup
: Module 1: QuickTime-Export - '4ca47bbf-2ca4-49ad-98b5-99936b2fed4c'
: Module 2: ~REDCODE RAW - '6ebf0150-a939-46d0-8132-73291d76b3bd'
: Loaded 2 FX plguins
18:44:06.97 INFO : Media Library initializing:
: File : '/Library/Redcine/Media//MediaLibrary.reg'
: Tracks: 1
: Loaded: 0
18:44:06.97 INFO : Load Local Library: '/Library/Redcine/Project/Session_1/ProjectMedia.reg'
: Tracks: 0
: Loaded 0 Local Tracks (0 total)
18:44:06.97 INFO : Setup media cache..
18:44:06.97 INFO : QuickTime 7.80.128 initialized
18:44:06.97 DEBUG: MediaBaseCtx: Load image IO format instances.
: Starting 4 IO-thread(s)
18:44:06.97 DEBUG: Media IC Ctx1: Load image IO format instances.
18:44:06.97 DEBUG: Media IC Ctx2: Load image IO format instances.
18:44:06.97 DEBUG: Media IC Ctx3: Load image IO format instances.
18:44:06.97 DEBUG: Media IC Ctx4: Load image IO format instances.
18:44:06.97 INFO : Load media from: '/Library/Redcine/Project/Session_1/Construct.reg'
18:44:06.97 INFO : Loading project
: Load Media (/Users/gregd)
18:44:06.97 INFO : Loading the node register (3 nodes).
: 2 new nodes registered.
: Total of 2 nodes registered.
: Total time 0.00 Sec (Resolving 0.00)
: Load Constructs
: Load Result Stacks
: Verify Construct setup
18:44:06.98 INFO : Project ready.
: Media resolved : 0.00 Sec.
: Construct setup: 0.00 Sec.
: Datamanager : 0.00 Sec.
: Total : 0.00 Sec.
18:44:06.98 INFO : Session initialize
18:44:07.13 INFO : 3D LUT: Enable FP16 texture format
: GFX: Use full (32 bit) floating point 1D LUT's
18:44:07.15 INFO : Initialize player
18:44:07.16 INFO : Initialize Player Session..
18:44:07.16 INFO : Render: Enabled FBO based render scheme!
18:44:07.16 INFO : Setup Timeline Player, Session 1
18:44:07.71 INFO : Session start
Here it is:
18:44:06.12 INFO : ================================================== =
: GLEW : 1.5.0
: R,G,B,A : 8,8,8,8
: Accumulation : 0
: Font manager..
: Tracks: 1
: Loaded: 0
: Tracks: 0
: Load Constructs
: Total : 0.00 Sec.
Resolved
Resolved
Turns out Redcine has been working, just displaying on my secondary monitor through Matrox MXO. Just have to figure out how to bring it back to main monitor now.
I have the same isssue. I always have to attach a second monitor if I want to use redcine. Kind of stupid.
It also locks the resolution to 1280x1024 75Hz, no matter what you set in preferences.
My main monitor only supports 1024x768 resolution and Redcine won't work on that.
Redcine will pick automatically the highest resolution monitor it think you have.
Tek
