Steve Freebairn
Color correction in inherent in the Premier application for whatever format.
What we are discussing is different than just color correction, it's assigning color temperature.
For example, if you shoot outside with the camera accidentally set to 3200K then everything is going to look really blue. You could try and color correct that so that it looked right, but if you could change the color temperature to 5600k, then it would give you a natural starting point to do your color correction.
