This seems to work great to make prores files. Is there something I'm missing as to why this wouldn't be used as the main way to convert the r3d files?
Because it doesn't let you go through with vast grading control as other choices. If you shot the footage with already perfect looks then L&T would be fast way to ingest footage.
