RELEASED: BETA REDAlert! (v3.4.5)
RL 100% without burn in.
This looks like a bufferng issue, because of burn in data plus full res images.
mmap(size=671354880)
Low res usually work even in prior two versions.
10.5.4
Thnx
Tek
REDline -i /Users/username/Desktop/A020/A020_080802.RDM/A020_C001_080802.RDC/A020_C001_080802_001.R3D --outDir /Users/username/Desktop/A020/Render_temp -w 11 -R 1 --useMeta --colorSpace 11 --gammaCurve 14 --makeSubDir --filter 5 --fit 1 --QTcodec 0 --resizeX 4096 --resizeY 1080
Low res with burn no problem.
100% in RR
100% in RL
Tek
REDline -i /Users/username/Desktop/A020/A020_080802.RDM/A020_C001_080802.RDC/A020_C001_080802_001.R3D --outDir /Users/username/Desktop/A020/Render_temp -w 11 -R 4 --useMeta --makeSubDir --filter 5 --fit 1 --QTcodec 0 --resizeX 640 --resizeY 480 --burnIn --burnSz 5.000000 --burnBase 2.500000 --burnLL 1 --burnLR 6 --burnUL 2 --burnUR 5 --burnTxtR 1.000000 --burnTxtG 1.000000 --burnTxtB 0.498039 --burnTxtA 0.800000 --burnBgR 0.392157 --burnBgG 0.392157 --burnBgB 0.392157 --burnBgA 0.800000 --burnFont 1
Agreed. Looks like a problem full res debayer plus resize plus burnin.
Should be able to find it now. Thanks!
The memory issue with doing a full debayer+resizing+burnin is fixed for the next release. If anyone needs a test build right away, PM me with your email address.
Is audio supported in new RedRushes upgrade v3.4.5?
Is it faster to render 2h of footage via QT_M files from Cam->Compressor(HD720ProRes), or via RedRushes(same settings)? RedRushes gives you more control and you can use quarter debayer res.
Thanks for the answers.
