RELEASED: BETA REDAlert! (v3.4.5)
Brent Carter
REDUSER.NET
Irvine CA
Now available on www.red.com/support .
RED ALERT! & REDline & REDrushes (v3.4.5)
Bug Fixes:
* Fixed bug for 59.94 files.
* Fixed bug for some long clips.
Thanks, BC
Little BUG in Redrushes.
Redrushes get stuck between 85 and 94 percents of clips while tryng to burn in TOD T.C. (same clips with no burn in runs smooth)
If I stop the clip before it get stuck then he plays well and the T.C is burned corectly.
Thank you Red team for all those amaizing developments.
Ido.
I tried 2 clips and both stopped on frame 477.
I did it at work yesterday before I left so I don't have access to the log.
Like the new tab based setup though. :tongue:
I can't recreate that problem here. Any more info you have would help.
Can you verify that REDline got installed properly? (in the terminal,
type REDline and check the version number at the top).
This is what happened in Redline using Redrushes export script.
Please help.
I also get dup 2 frames repeating.
Tek
REDline(476,0xb032b000) malloc: *** mmap(size=671354880) failed (error code=12)
*** error: can't allocate region
*** set a breakpoint in malloc_error_break to debug
A020_C001_080802.mov : 38
REDline(476,0xb01a5000) malloc: *** mmap(size=671354880) failed (error code=12)
A020_C001_080802.mov : 39
A020_C001_080802.mov : 40
A020_C001_080802.mov : 41
A020_C001_080802.mov : 42
A020_C001_080802.mov : 43
A020_C001_080802.mov : 44
A020_C001_080802.mov : 45
A020_C001_080802.mov : 46
A020_C001_080802.mov : 47
A020_C001_080802.mov : 48
A020_C001_080802.mov : 49
A020_C001_080802.mov : 50
A020_C001_080802.mov : 51
A020_C001_080802.mov : 52
A020_C001_080802.mov : 53
A020_C001_080802.mov : 54
REDline(476,0xb01a5000) malloc: *** mmap(size=37748736) failed (error code=12)
Bus error
Script:
REDline -i /Users/username/Desktop/A020/A020_080802.RDM/A020_C001_080802.RDC/A020_C001_080802_001.R3D --outDir /Users/username/Desktop/A020/Render_temp -w 11 -R 1 --useMeta --colorSpace 11 --gammaCurve 14 --makeSubDir --filter 5 --fit 1 --QTcodec 0 --resizeX 4096 --resizeY 1080 --burnIn --burnSz 5.000000 --burnBase 2.500000 --burnLL 1 --burnLR 6 --burnUL 2 --burnUR 5 --burnTxtR 1.000000 --burnTxtG 1.000000 --burnTxtB 0.498039 --burnTxtA 0.800000 --burnBgR 0.392157 --burnBgG 0.392157 --burnBgB 0.392157 --burnBgA 0.800000 --burnFont 1
In RedRushes - If I use External/TOD when Looks Source is set to RSX I get an error. If I set to Edgecode it'll render but it doesn't have the look from the selected RSX applied.
Is anyone getting RSX Looks from one file to apply to other files? Maybe I'm just doing something wrong.
Does that happen on all the clips you render?
Can you try it without the burnIn option?
Script:
Can you output the metadata on the clip for me?
Do you have selected RSX chosen in the menu?
Yes.
Debayer: Quarter
Timecode: Edgecode
Look Source: RSX
Color Space: Look Source
Gamma Space: Look Source
RSX Settings:
RSX Source: Selected RSX
In/Out Point - Ignore
Does the RSX of a clip automatically get updated anytime a color correction change is made in Red Alert? I don't have to do anything to save that do I?
No, it updates the RSX automatically. As soon as my machine is available again, I'll do a test as well.
It gets automatically updated.
Maybe try deleting REDalert, redline (/usr/sbin/REDline), and redrushes and reinstall. Occasionally we've seen the OSX installer not work properly.
OK, deleted all 3 apps and reinstalled. Still not working for me. Seems to be giving me the camera metadata every time. Just tried a burn in QT Prores HQ and that didn't work either. Weird.
RedLine is 3.45 and so is RedRushes.
Deanan small question please... know you are very busy....
I need to work at a soon project on a quad core mac pro with OSX 10.4.11 installed.... do you recommend to upgrade to 10.5.4 for working with B16 footage???
thx
rainer
RLX
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>DRX</key>
<real>0.0</real>
<key>blackLevel</key>
<real>800</real>
<key>blackX</key>
<real>0.0</real>
<key>blackY</key>
<real>0.0</real>
<key>blue</key>
<real>1</real>
<key>brightness</key>
<real>0.0</real>
<key>contrast</key>
<real>0.0</real>
<key>curveActive</key>
<true/>
<key>exposure</key>
<real>0.0</real>
<key>green</key>
<real>1</real>
<key>inputBlackX</key>
<real>0.0</real>
<key>inputWhiteX</key>
<real>1</real>
<key>kelvin</key>
<real>5600</real>
<key>kneeX</key>
<real>0.75</real>
<key>kneeY</key>
<real>0.75</real>
<key>midX</key>
<real>0.5</real>
<key>midY</key>
<real>0.5</real>
<key>red</key>
<real>1</real>
<key>saturation</key>
<real>1</real>
<key>tint</key>
<real>0.0</real>
<key>toeX</key>
<real>0.25</real>
<key>toeY</key>
<real>0.25</real>
<key>whiteX</key>
<real>1</real>
<key>whiteY</key>
<real>1</real>
</dict>
</plist>
RSX
<dict>
<key>currentSidecar</key>
<dict>
<key>ISO</key>
<integer>320</integer>
<key>currentDate</key>
<date>2008-08-09T21:14:37Z</date>
<key>currentFrameNumber</key>
<integer>0</integer>
<key>inFrameNumber</key>
<key>inputFilePaths</key>
<array>
<string>/Users/username/Desktop/A020/A020_080802.RDM/A020_C001_080802.RDC/A020_C001_080802_001.R3D</string>
</array>
<key>maxHistory</key>
<integer>10</integer>
<key>metadata</key>
<dict>
<key>DRX</key>
<real>0.0</real>
<real>800</real>
<key>blackX</key>
<real>0.0</real>
<key>blackY</key>
<real>0.0</real>
<key>blue</key>
<real>1</real>
<real>0.0</real>
<key>contrast</key>
<real>0.0</real>
<true/>
<key>exposure</key>
<real>0.0</real>
<key>green</key>
<real>1</real>
<real>0.0</real>
<real>1</real>
<key>kelvin</key>
<real>5600</real>
<key>kneeX</key>
<real>0.75</real>
<key>kneeY</key>
<real>0.75</real>
<key>midX</key>
<real>0.5</real>
<key>midY</key>
<real>0.5</real>
<key>red</key>
<real>1</real>
<real>1</real>
<key>tint</key>
<real>0.0</real>
<key>toeX</key>
<real>0.25</real>
<key>toeY</key>
<real>0.25</real>
<key>whiteX</key>
<real>1</real>
<key>whiteY</key>
<real>1</real>
</dict>
<key>outFrameNumber</key>
<integer>319</integer>
<key>preferences</key>
<dict>
<key>CNR</key>
<key>PDBlack</key>
<real>85</real>
<key>PDGamma</key>
<real>0.60000002384185791</real>
<key>PDWhite</key>
<real>685</real>
<key>colourSpace</key>
<integer>11</integer>
<key>defaultExportFolder</key>
<string>~/Desktop</string>
<key>detail</key>
<integer>8</integer>
<key>doUseDefaultExportFolder</key>
<false/>
<key>fullDenoise</key>
<key>gammaType</key>
<integer>14</integer>
<key>noExt</key>
<false/>
<key>processors</key>
<integer>2</integer>
<key>redBlack</key>
<real>50</real>
<key>sharpenStrength</key>
<integer>100</integer>
<key>useAudio24</key>
<false/>
<key>useEdgeCode</key>
<false/>
<key>useNA</key>
<false/>
</dict>
<key>versionString</key>
<string>0.2 (c) 2008 RED Digital Cinema</string>
</dict>
<key>editHistory</key>
<array>
<dict>
<key>ISO</key>
<date>2008-08-09T21:14:36Z</date>
<array>
</array>
<key>metadata</key>
<dict>
<key>DRX</key>
<real>0.0</real>
<real>800</real>
<key>blackX</key>
<real>0.0</real>
<key>blackY</key>
<real>0.0</real>
<key>blue</key>
<real>1</real>
<real>0.0</real>
<key>contrast</key>
<real>0.0</real>
<true/>
<key>exposure</key>
<real>0.0</real>
<key>green</key>
<real>1</real>
<real>0.0</real>
<real>1</real>
<key>kelvin</key>
<real>5600</real>
<key>kneeX</key>
<real>0.75</real>
<key>kneeY</key>
<real>0.75</real>
<key>midX</key>
<real>0.5</real>
<key>midY</key>
<real>0.5</real>
<key>red</key>
<real>1</real>
<real>1</real>
<key>tint</key>
<real>0.0</real>
<key>toeX</key>
<real>0.25</real>
<key>toeY</key>
<real>0.25</real>
<key>whiteX</key>
<real>1</real>
<key>whiteY</key>
<real>1</real>
</dict>
<dict>
<key>CNR</key>
<key>PDBlack</key>
<real>85</real>
<key>PDGamma</key>
<key>PDWhite</key>
<real>685</real>
<key>detail</key>
<false/>
<key>noExt</key>
<false/>
<key>redBlack</key>
<real>50</real>
<false/>
<false/>
<key>useNA</key>
<false/>
</dict>
</dict>
</array>
</dict>
</plist>
Hey Tekcin,
Sorry, I meant the output form printMeta from redline in the terminal:
REDline -i /Users/username/Desktop/A020/A020_080802.RDM/A020_C001_080802.RDC/A020_C001_080802_001.R3D --printMeta 1
