Joe G.
Please use this thread to post side by side screen shots and/or footage of the same material in Red and in Cineform. I would like to compare quality.
so we will primarily be do 4:4:4 CineForm encodes until the SDK supports RAW (faster transcodes to small file sizes.)
There is little point in the comparison, as the source will always be Redcode. If the Rawport wasn't discontinued, then the comparison would have been possible. While CineForm RAW can be applied to ARRI, Dalsa, Phantom or SI footage, different cameras and therefore different results. For Red foootage, CineForm is an online post and DI format, just as we are for every other compression or non-compressed camera source. CineForm 444 as DI is quality visually equivalent to posting with DPX files, just 4 to 7 times smaller files. We look forward to implementing the Redcode SDK, allowing easier conversion of Red media into the CineForm workflow.
__________________
David Newman
CTO, CineForm
The only difference is that CineForm is fatter proxy allowing you to play real time right from the CineForm file without necessity of converting it to the QT but rather converting it to the CIneForm.
Is that right or I am getting confused here?
I would love to have CIneForm proxies created at the end of the clip on RED during the “POST” instead of QT proxies.
I was always thinking about CineForm as a proxy file to the original RAW whatever it comes from.
Kind of like the QT proxy file on RED that is saved together with the RED RAW file when you finish the clip.
Once you have the files in the Cineform 444 format (codec), it's the simplest most straightforward post process possible.
-Thor
Andrew,
The Cineform files are actually online quality. There is no need to conform like you do with proxies.
Transcode from Red RAW to Cineform 444. Then edit, grade, export your master file... you're done. Print it to tape, master it to DVD or Blu-Ray, or do a film out.
-Thor
Hey Thor,
When do you transcode? Can you transcode from redcine to Cinefrom 444?
