Hi!
Did anyone figure a way to prevent the RED DRIVE from getting dropped frames when experiencing vibrations, and STILL keep it inside the Red Cradle?
I'm thinking to drop the RED's standard way to mount the drive in the cradle - I'll just remove the stock mounting system (the two sliding plastic rods). Instead, I'm thinking to either just wrap the drive in bubble wrap and simply slide it inside, or permanently attach foam to the top and bottom of the cradle's insides, leaving enough space to just slide the drive in between the foam.
Before I start, I'm wondering if anyone did something similar already, with good results (zero dropped frames).
Thanks!
PS I don't plan to move to ET's shock-mount system or anything like that, since I already bought the cradle and would like to keep using it.
Thanks!
