1080p playback messes it up...
filmstyle
I'm using 17' HDLCD, and it is connected via HDSDI.
On Red setting, 720p playback works great, but when I change it to 1080p playback, everything turns green. like... viewing through the green filter. (still I can recognize the shape of something...)
Even on EVF, it appears to have same problem, so I don't think it's LCD's fault.
Does anybody have same problem? or I've messed up something?
Already reported since 1080p playback was enabled. Green Screen for Panasonic 17" LCD when on 1080p playback. Nobody seems to bother anyway - so do not use 1080p for playback. Lim
:calm: It is quite funny how no one seems to care?
Emmanuel
Green Video
Green Video
Are you connected to one of the two connectors labeled HD-SDI, instead of the one labeled PVW?
If so, you are looking at 1/2 of a 1080p 4:4:4 RGB dual link HD-SDI signal and that will be green yes...
Try swapping over your HD-SDI cable to the PVW out as that is 1080p 4:2:2 in playback.
Playback in 1080p works fine
Stuart, since I have covered the four ports out with the ET breakout box, I assumed you are saying the port that ET labeled as 720p out. I always thought it is PVW at 720P as an option in the PVW OUTPUT menu ie either as VIDEO(720p) or MENUS [DVI] - Lim
