EVF screw size/ mounting ?
Marc Berger
France
www.mabcine.com
Hi,
I´m looking for a picture of the EVF from the back side (Where you mount the arm). I can´t find any.
I also would like to know the exact specs of the screws to mount the EVF.
Anybody can help?
Thanks!
Marc
Also great would be to know the distance between the two screws (if there are two).
Thanks!
Marc
I believe they are 3mm
I certainly hope not. The camera is covered in 1/4 x 20 tapped holes, thats whats on the end of most Noga arms, so it would be bordering on criminally stupid to make it metric.
Nick
That´s it, sure. Thank you Nick! Do you also know how much threads are in the EVF? The distance in between? Picture please!
Marc
The EVF has a small block that mounts on its side with screw holes (1/4-20). EVF ships with this block in place. But this block attaches to the EVF via 4 really small screws, much smaller than 1/4-20, I don't know for sure what they are. When using the ET EVF mount, you remove this small block and use the 4 small screws to attach the EVF to the mount's support arm.
Maybe I can take a couple pictures in a bit so people can see what I'm talking about.
