Steve Sherrick
I wonder if the 17" models across the board suffer a bit from off axis. Even the TV Logic monitors in the 17" version suffer from color shifts off axis. The 24" does not have the same problem. I've also found the blacks can be reproduced pretty well with their ND glass filters, although reflection does go up, so you have to set up your room and the lighting well to avoid it.
Guess there are a lot of compromises in the sub $25K range of monitors. Just have to set your budget and get the best monitor you can afford based on direct comparisons, and not specs in a brochure.
