David Taylor
- Feb 14, 2007
CineForm's updated Mac workflow (BETA) has been posted and is available for download from the Downloads section of the website. There are a number of new features in this build including:
We'll get the first rev of our Tech Note published in the next day or two. Currently documentation is a bit sparse. Please let us know what comments you have.
- Second monitor support
- New panels for Active Metadata. A global Active Metadata panel is now located in /Sytem/Preferences. Clip based Active Metadata controls are made through the SetActiveMetadata utility located in /Applications/CineForm. When experimenting with Active Metadata you'll normally want to use only the SetActiveMetadata control (not the global control). The SetActiveMetadata panel should be kept active while using either FCP or QT Player for dynamic adjusting of color information.
- Active Metadata is now supported for CineForm 444 clips also with identical operation to that in FCP. This means you can render out from RAW without baking in color information, then apply Active Metadata on the CF-444 clips instead.
