Two Reds/half stop difference
Michael Carn
We recently upgraded our two cameras (748 and 1281) to B16. Set them up in the studio for a colour chart test and there was a half a stop difference on the same setup with the same lens with the in camera readings.
Any ideas?
Maybe use "restore" on both cameras to be absolutely sure that they are both back to factory presets, then check the side by side again.
David
I think Black Shading is the reason here.
Isn`t the reason we have black shading in the first place to calibrate each individual sensor photosite, because they can vary in sensitivity due to the manufacturing process, even across a single sensor? Wouldn`t that therefore mean a given sensor could have a higher average sensitivity compared to another? I would perform another blackshading anyway
