Non-Red battery use void warranty?
Rob Gardner
Does the use of non-Red batteries void the Red warranty?
Rob Gardner
As I understand it, it depends on the plate you use not the battery itself.
I use the Batteries4broadcast 150Wh batteries. My understanding is they are safe only when used with their GT-TS Hot swap/dual mount which also regulates the power to a safe level. I could be wrong about this but I would have purchased it anyway to reduce the need to shutdown for a battery change.
Can we be specific about what batteries are considered compatible?
Rob Gardner
Do you happen to know if the Red Charger will work with batteries from Batteries4broadcast (SM-4010), or do you use one of their chargers like C2-SM4010 or C4-SM4010?
