Bug II
Gunleik Groven
REDuser Sponsor
Norway
quine.no
The LCD output seems to all of a sudden have become randomly bad (but not as constantly as it was when I went directly from 15 2.2.8 to 16 1.3.6
Stymptomps:
Green goo
Pixels shifted (so that corors are 1-2 pixels "off")
Magenta Cast
This is NOT on the recorded image
Solution seems to be to stop recording fopr a while or power down for a while...
Did I say "solution" :)
hm...
Stymptomps:
Green goo
Magenta Cast
hm...
do you have another cable?
have they opened the RED NORWAY shop yet?
I am now testing with additional monitor, but the whole thing started during the upgrade, and mostly went away when I did a sequential upgrade of the B16 builds, so I do sorta connect the two incidents.
But there's plenty of RED shops around the corner :)
Could also be coincidence. I'd do a RESTORE, see if you still have the issue, then test another lemo cable.
I'll do it tomorrow, doing a long (and I guess quite boring...) testshoot tomorrow. Using the event of world record backwards cycling (+120km) as an excuse... :)
Can't you just film the guy cycling forwards and reverse the clip in post? That would save him some trouble...
I have noticed that the "all blue" LCD display has happened a couple of times on startup in B16. Also on dark scenes that display has some what looks like dead pixels that do not appear on the file.
David
I follow all the steps, upgrade, blackshading, etc.
