RED, Build 16, and strobes
David Mullen ASC
Moderator
www.davidmullenasc.com
So I get a note today that one scene in an upcoming project may have a lot of camera flashes and strobes going off, as if at the opening of a big movie premiere or fashion show...
... do I tell the director to drop the idea or can the RED now handle that sort of scene lighting without the split-frame artifact?
Timing of strobes is still an issue.
Are you able to control the length of the strobe or timing of the strobes?
Just did a shoot with the red carpet and flashes motif. Had to quit after two takes when I realized the problem with the split frames, presumably caused by the way the sensor scans. I was planning on doing some testing this weekend to find a cheat around it. Doesn't sound hopeful since I'm still on build 15.
just add the flashes later....easy enough and looks good done right
i still haven't been able to recreate that slip frame artifact every flash or light on/off has been fine. don't know if I just lucked out or what :/
We used a Martin light hooked up to a light board because the flash happens over a slightly longer period, so it doesn't cause the split frame effect.
Edit: I posted, then remembered how dumb it was that I was replying to David Mullen, since he wrote several of the film books I learned from, Sorry, David, I'm sure you know tons about the subject.
They look great though...
You can also get slow burn versions which easily touch 2-3 frames and produce lovely exposure tails.
regards
Michael
We usually use *slower* and longer flashes or HD CCD-FIT basing digital cameras who dont have any readout/rolling/mechanical shutter to make things easy.
Will the RED sync with strobes? The Phantom will and the shutter protocols should be fairly similar. It is just whether there is an output from the camera to control this sync. Leading edge, duration, etc.
Has anyone encountered the dreaded split screen effect with police car lights? Essentially they can appear kind of strobey. Imagine how many films you see police/ambulance/fire-truck lights in...that's Jerry Bruckheimer out...:biggrin:
