Thing is: and this is somewhat confusing, but the shutter angle is actually irelevant because the shutter speed changes anyway when we change the frame rate. As opposed to film where the angle stays (unless we change it) the same (normally 180 or 172.8) and the shutter speed changes as we change the frame rate...
Yes, I remember there being some discussion on this before - I can't remember if someone put up a really good reason for this not being the case, so apologies if we're retreading old ground (and also with an acknowledgment that the Red team are obviously frying bigger fish at the moment), but:Ideally switching to degrees display would automatically change the shutter to RELATIVE mode (yellow display), as this is the only way the display makes sense, but I can understand you might want the choice.
Our kit just went out on a drama shoot with a great DP named Simon Dennis (who is no fool, I might add) who shoots a lot of 35mm. I had to talk him through the shutter system several times as it is so counter-intuitive to have a shutter angle readout that does not change the exposure time vs framerate - it just makes no sense at all!
