Exporting .tiff sequence ( Redcine overwriting same file ) ??
maddog2002
New member
Hello everyone, good to be in this forums...
Let me go straight to the problem:
I have some footage I have to work with, shot with the RED Cam, I have opened the raw footage in REDCine, and I`m trying to export a sequence of 16 bit tiff images...
I have selected the PDLog setting, I have set the output path, and everything, then I start rendering out the sequence...
The problem is that REDCine, instead of creating a sequence of numbered stills ( Ej. whatever001.tiff etc etc ) , it keeps overwriting the same image ( whatever.tiff ) so, i just end up with just the last rendered frame...
pretty odd thing, or there`s a very obvious setting I`m not seeing... :wacko:
I would apreciate it very much if anyone could help me through this...
nevermind i found the solution... i was making a syntax rr n the filename convention hehe... :whistling:
Hi together,
I got the same problem but have no clue what
"making a syntax rr n the filename convention"
would mean!?!?!
Pleas help. What am I doing wrong?
